Sky+ Code for LG50PC56
U
Uncle heFTy
Try as I may, and I have contacted Sky, I cannot get my remote to work with my LG50PC56. Has anyone else had the same problem. Sky gave me code 0206, but even that doesn't work. Help!!!
Uncle H
drizzle2
Hi see my earlier posts for my LG 26 LCD,like you I have lists and lists and I wrote to LG but they gave me a code for sky not sky+ but say it is out of their hands and is all to do with sky.Sky just give you more lists.
I am going to try upgrading to REV8 tomorrow and see if that will work.
If only I had read of the probs here before I bought.Doh!
Will post my findings tomorrow.
Good luck and keep board informed for the benefit of new users.
Kate:smashin:
K
Kesgarevboy
Hi there, I have the same TV (LG50PC56) I found the code on Sky+ Box in the end after a little seaching. The code I used was 0206. I found this code to work perfecly on my LG50PC56 and had no problems with the remote or the TV.
Mick_the_Beer
This may be of help to you.
I have an LG42PC1DA plasma and I had to contact Sky for the Sky+ code.
The code I was given was also 0206 and it wouldn't work either.
I was also told that if your Sky+ box was a new one then the code was 3 digits and not 4. So I entered 206 and it works perfectly.
davemurgatroyd2
Kate:smashin:
Codes are the same for Sky and Sky+ - the differences between 4 and 3 figure codes AND some codes not being accepted by the remote are due to the age of remotes (revision number) NOT whether they are Sky or Sky+. What revision number is your remote - should be on a white sticky label inside battery compartment. The latest revision is 8 and earlier remotes will almost certainly not work with the very latest TVs unless that TV manufacturer is using still "older" codes from earlier TVs.
