sky code for Daewoo
Discussion in 'Sky Digital TV Forum' started by gw3xjc, Sep 21, 2007.
  1. gw3xjc
    gw3xjc
    Sep 19, 2007
    13
    3
    Nr. Cardiff
    Sky Remote Code For Daewoo
    Does anyone have a definitive code for using a sky remote control on a Daewoo DUB- 2850 GB television. I have tried various codes on these site and I have not found one that works as yet. If I use the volume it will change channels etc.
    Regards Roger Luke GW3XJC
  2. Adrian_F
    Adrian_F
    Jun 29, 2007
    1,426
    83
    +293
    Try these 0664,0404,1939
  3. gw3xjc
    gw3xjc
    Sep 19, 2007
    13
    3
    Nr. Cardiff
    i will give them a try, thanks Roger
  4. Chip Nicley
    Chip Nicley
    Oct 2, 2006
    165
    +15
    Have a look on SKY Interactive, Sky customer service programme your Sky remote follow instuctions.
    Cheers:thumbsup:
  5. gw3xjc
    gw3xjc
    Sep 19, 2007
    13
    3
    Nr. Cardiff
    thanks, i will give it a try
  6. edenmanor
    edenmanor
    Aug 4, 2006
    4
    darlington
    hi, i had the same problem with my daewoo dub 2850 gb none of the codes worked for the volume. i bought a new remote from a sky engineer who was working at a friends house, cost me a tener used code 0662 works great.
