Sky+ coax cable... will RG59 do ?
Discussion in 'Sky Digital TV Forum' started by ctcrm, Jul 31, 2005.
  1. ctcrm
    ctcrm
    May 6, 2003
    134
    Hello all, Im waiting for sky's engineer to install sky+ and multi room which I want inside a bedroom wardrobe.
    My plan is to install all the cables to the boxes and dish so the engineer only has to connect up with no fuss and no visible cable.
    I install cctv for a living and have gallons of RG59 coax cable which has an air spaced core and is 75Ω, ive noticed the sat cable has a solid insulator between the main conductor and braid.
    Can I use my cable for the install ???
    Regards
    Paul
  2. SamRadford
    SamRadford
    Jul 12, 2005
    3,965
    103
    N. Yorkshire
    +308
  3. ctcrm
    ctcrm
    May 6, 2003
    134
    yes cctv, not sat !!
    i have no idea what that requires, but thanks i will check that link!
  4. ctcrm
    ctcrm
    May 6, 2003
    134
    hmme thats pretty much inconclusive...
  5. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    The specs of RG59 vary from maufacturer to manufacturer, so compatablity for satellite TV use cannot be guaranteed. CT100 is made to a much tighter spec for that particular job.
  6. SamRadford
    SamRadford
    Jul 12, 2005
    3,965
    103
    N. Yorkshire
    +308
    I would have thought it was very conclusive. RG59 doesn't even get a mention because it's not satellite cable.
  7. BDCSTENG GARETH
    BDCSTENG GARETH
    Jul 5, 2005
    347
    Sutton, Surrey
    +8
    RG59 is almost the same spec as PSF 1/3. I've used 1/3 many times, and worked well... If you work in CCTV, then you have the cable available to "suck it and see".
    Gareth.
  8. ctcrm
    ctcrm
    May 6, 2003
    134
    ill make a patch lead tomorrow and see for myself.
