Sky + Classic FM
Discussion in 'Sky Digital TV Forum' started by maverick177uk, May 26, 2005.
  1. maverick177uk
    maverick177uk
    Jun 1, 2004
    4,416
    +700
    This is the only channel that breaks up on my system any ideas how to solve this, I've never been able to watch it since it was installed last November
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +975
    I would have thought it was impossible for only a single channel to be breaking up unless there was a problem with the source itself.
    More likely you are having problems with all the channels on that particular transponder but you just don't know it yet:)
    Try these..
    EPG 262 (open access)
    EPG 828 (Vectone)
    If you can not receive them then it's likely that your dish/lnb need a slight adjustment, this is covered by the warranty.
    To clarify, is it that TV or Radio version of Classic FM ?
  3. maverick177uk
    maverick177uk
    Jun 1, 2004
    4,416
    +700
    Tv one mate will have a look now ,yep they're buggered as well oh well will phone Sky thanks for the help :)
  4. notsosure
    notsosure
    May 26, 2005
    9
    did you get this sorted? was it just the dish slightly out of line?
    I have the same problem with this group of channels. Have tried different digiboxes, improved cable quality etc, but still get periodic problem.
    I am living in new build apartment so have communal dish, which the management wont fix because I am the only one reporting the problem!
