  2. Notice: AVForums will be offline at 10pm for no longer than 30 minutes for scheduled maintenance. Apologies for any inconvenience this causes.
Sky+ causing hifi hiss
Discussion in 'Sky Digital TV Forum' started by stickybz, May 18, 2005.
  1. stickybz
    stickybz
    I have just upgraded to sky+ and have developed an annoying hiss through the hifi. This is present on all amp channels (not just sat) and disappears when the sky box is in standby mode, and is not dependant on amp volume setting. The digibox is a few feet from the hifi but, due to limited space, the 2 cables from sat dish do pass close to the speaker cables (no easy way around this). The sky+ box is connected through an optical link to the amp.
    Ive tried moving power cables etc with no luck. Do I need to consider upgrading the 2 cables from sat dish to box? If so any recommendations? :lease: Isn't this something the sky installers should do?
    Thanks in advance.
    Sky+ Pace 3100, Arcam AVR250/DV79, Kef Q7/2Qds/Q9c
  2. JayCee
    JayCee
    Jan 20, 2004
    20,082
    Lanarkshire
    +1,914
    The coax cables from the Lnb on the dish to the Sky+ are unlikely to be the cause of the hiss......have you tried disconnecting the optical lead and tried maybe a phono to phono to see if the hiss is still there?
    Well, if you have upgraded from Sky digital to Sky+ surely they had to run another coax from the dish? :rolleyes:
  3. stickybz
    stickybz
    Nope that didnt do it, thanks for good idea though.
  4. sillybeans
    sillybeans
    Whats the volume like through the tv without the amp? Have you tried another scart cable? (Should not make a difference but worth a try)
  5. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    The hiss is probably being generated by the switched-mode power supply in the Sky+ box, and picked up via the amp power cable. Since the hiss is independent of the volume control, it is unlikely that it is being picked up by other wiring. An in-line power filter or clamp-on ferrite filter could be the answer.
  6. stickybz
    stickybz
    thanks again for the advice. Have just ordered a ground loop isolator (before reading your posts). If this doesnt work think ferrite plugs will probably be next step.
    Cheers (Ill let you know if it works)
  7. stickybz
    stickybz
    just an update. The ground loop isolator was delivered through the cat flap. My lab was very pleased at her new prezzie and bit it into little pieces! Gave up with the idea and bought a belkin mains extension (with filters). The hiss is now inaudible at normal listenening distances. Thanks again for all the advice.
  8. anthonyg
    anthonyg
    I've got a belkin doo dah, pretty nifty for the price (£70) 8 way extension with power cleaning and surge protection on mains, RF, telephone and sattelite (though it only as one sat filter, they didn't count on sky+)
