Sky + capture using HCPC
Discussion in 'Desktop & Laptop Computers Forum' started by pcpaz, Aug 24, 2004.
  1. pcpaz
    pcpaz
    I have heard good things about the quality of capture using a Sky + box. I would like to replicate the same quality using a HCPC, anyone got ideas what's the best way to do this and what type of capture card to use.
  2. Dr Downey
    Dr Downey
    Jan 12, 2004
    124
    19
    Cheltenham
    You'll need some good big hard drives, and a good video capture card like a Hauppauge PVR350, or one of the Pinnacle boards.
    Sky + advantage is that it has 2 tuners, so can record a different programme to the one you are watching, it also doesn't record the 'red dot' interactive icons, or any of the on screen navigation that you would get if you record the video output of the sky system.
    Good luck!
  3. David PluggedIn
    David PluggedIn
    Oct 14, 2003
    544
    +10
