Sky+ Capacity following disk upgrade
Discussion in 'Sky Digital TV Forum' started by uk_jih, Dec 15, 2003.
  1. uk_jih
    uk_jih
    Mar 17, 2003
    175
    +6
    I upgraded my Sky+ (V1) box yesterday to a 120gb disk.
    Everything went ok but I see no difference in capacity. A 1 hour program still takes 5% and the length of the bar at the top is still correct for 5%.
    My box has the new software which allows dual recording and I just wondered if $ky had done something to stop Sky+ boxes recording more than 20 hours of programmes. :confused:
  2. Luc
    Luc
    Aug 7, 2000
    417
    AFAIK it's a bug in the firmware that doesn't calculate space correctly. it was ment to have been fixed, but obviously not. You can still record stuff over 100% i think...
  3. DaveP
    DaveP
    You'll get a disk full message when the 26% has been used, ignore this and you will then get 34% free!. As this fills again it will again give a disk full message and then again you will get 34% free.
    It is just like having three 40gb disks as far as the software is concerned. No idea why it starts at 26% though!
    Dave
  4. uk_jih
    uk_jih
    Mar 17, 2003
    175
    +6
    Will the full message stop the box from recording?
  5. deman77
    deman77
    Aug 20, 2003
    260
    16
    London
    do you need to disable autodelete functionality?
  6. philipb
    philipb
    Mar 6, 2002
    1,980
    63
    Swindon
    +129
    It'll go on recording until the 120GB is all used up. The progress bar should show how much space has been used - the %age figures are wrong.
  7. new
    new
    sorry for being a thickey here but how did you upgrade your hardisk?
  8. uk_jih
    uk_jih
    Mar 17, 2003
    175
    +6
    I bought a 120gb maxtor disk.
    However, I opened the box, took out the 40gb disk, very similar to a PC setup, put the old 40 gb disk back in and then expected to have 120gb. Doh!
    I only found out when I checked the old disk and found it was the new 120gb disk.
    Everything is working now, I see what you mean about the %.
    Took about 15 mins in total.
  9. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    Take a look here for a version 2 SKY+ or here for the original SKY+.
