Sky Cables To Connect Box From Wall Socket
Discussion in 'Cables & Switches' started by PikPik Carrot, Sep 13, 2005.
  1. PikPik Carrot
    PikPik Carrot
    I am going to be putting a wall socket in for my sky and tv ariel. I would like to know what good quality cables there are to go from the wall socket to the sky box, the only F Type connector cable i can find is the cheap bog standard ones(think argos sells them) and one by QED called Qunex STV which is about £35. How good is the QED one and how much does it improve the picture?? what other ones are there that i can check out ? looking to get one that gives high quality picture, i dont really want to use one of those bog standard ones.
  2. loadsofleads
    loadsofleads
    The QED ones are very good, but your paying for that quality. Best thing to do is get some good quality shielded coaxial cable (eg. CT100) and get some F-Type connectors and DIY, won't be any different than the cable from the dish to the wallplate :smashin:
