SKY+ cables separate for RBG and audio?
Discussion in 'Sky Digital TV Forum' started by Andrew46, Jan 29, 2005.
  1. Andrew46
    Andrew46
    I have Sky+ and am about to buy a Pioneer PDP505XDE 50inch plasma screen. I will also buy a separate home video system (pioneer DCS-525). I understand that RGB-only Scart gives best video and so thought to use that from the SKY+ box to the Plasma set-top unit instead of fully-wired scart. I see the SKY+ box also has phono out for audio. So should I use that for the audio to the home cinema box? I hear phono is not that great, but then I am not looking to have the best ever audio system. So is it okay to separate as I suggest or simply go for fully wired Scart?
    I've done some homework on this stuff (not that technically minded) and fear a little knowledge is now confusing me. Hope someone can help.
  2. Gavlaw1
    Gavlaw1
    The RGB output to your plasma will give the best picture. For audio, the Sky+ box has an optical digital out that will hook into most cinema amps - this will give you SKy+ in 5.1 surround, which Sky often broadcasts.
  3. Roohster
    Roohster
    Jul 1, 2004
    2,557
    Derbyshire
    +1,283
    Sky+ has a digital optical output (TOSlink) which will give you Dolby Digital on several of their movie channels.
    Use this for the audio connection to your DCS-525 and either an RGB only or fully wired screened scart to the tuner box.
  4. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    A RGB to VGA convertor (from JS Technologies) has been spoken well of when connecting SKY to a Plasma panel with VGA input. Worth asking for opnions in the Plasma forum, there will be quite a few people with real life experience of the panel and that type of connection.
