Sky+ Cable
Discussion in 'Sky Digital TV Forum' started by digitalwolf, Aug 18, 2005.
  1. digitalwolf
    digitalwolf
    Aug 18, 2005
    303
    Midlands
    +4
    I have limited access as to where the cable can enter my house. It was difficult getting the cable into the house as a shed is about 20cm from the wall.
    I have seen on a friends install,this cable sky have installed which is the same thickness as CT100 but contains two skinny cables, hence 2 feeds for sky+.
    What does everybody think of this cable? Signal strength, quality drop?
    Is it as good as having 2 direct lengths of CT100?
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    No direct experience but from what I have read the general concensus has been that the CT63 (Shotgun) cable should only be used for the shorter cable runs due to performance drop offs.
  3. av2diefor
    av2diefor
    CT100 will give the best performance, the "shotgun" cable is only reccomended for distances of 20m or less.
  4. digitalwolf
    digitalwolf
    Aug 18, 2005
    303
    Midlands
    +4
    My cable run is 8 meters,so I should be alright!
  5. av2diefor
    av2diefor
    TBH, i fitted it at home at 28m and its spot on, nice and neat.
    If your doing it yourself remember the f connectors are smaller as the cable is 4.8mm dia.
  6. SamRadford
    SamRadford
    Jul 12, 2005
    3,965
    103
    N. Yorkshire
    +308
    8 meters is not a problem. According to Satcure it's OK up to 20 meters. (Obviously this refers to a Sky minidish. If you use a larger dish where a minidish would normally give enough signal, then you can use a longer cable.
    Specifications here:
    http://www.satcure.com/tech/cablespecs.htm
    "Nominal attenuation" is the important bit.
    Also note that this cable requires special "f" connectors as shown here:
    http://www.satcure.com/accs/page7.htm#fconn
