Hi all,
I have sky+ in my front room, the twin coax cable which was installed by sky has been run under the skirting to the furthest alcove in the room. We have now had a re-structure so I needed the sky+ box in the other alcove. I didnt want to tear up the skirting to release the long cable, so instead I cut the small piece of cable still visible (which comes in by the alcove I want the TV in) in order to use F-connectors and a new piece of cable to add on to make a new length leaving the old behind the skirting.
I bought a length of cable from maplins (Twin Satellite Coax Cable : TV, Satellite Coax Cable : Maplin)
which i added f-connectors (4) to each end and also to the newly cut end of the existing cable and connected them with two joiners. However, the new piece of twin coax from maplins is a lot thicker than the original cable and so I have had to use tape on the original cable in order to attach the two screw fit f-connectors.
I managed to get all this done and all seemed to be ok, until we started to drop channels. Channels would not work then they would come back and a different one would go. I have re-done all the connectors making sure the right amount of copper is exposed but cant figure it out.
Has anyone got/had a similar issue? Remember I have not extended the cable in length so dropping signal due to extension cant be it.
I have now bought a new lenght of cable which has the connectors pre-fit so I can not worry about my handy work.
please help a frustrated man out.
Cheers all
Gareth
PS - sorry it's War & Peace
Cheers all
Gareth
