AkhilStyle
I have Sky+ HD and I have one of those double Sky cables coming into my house from the dish and under the ground to my TV.
I noticed that record wasn't working properly and on further investigation it says signal cable 1 is fine/has signal, but none for cable 2. Had a look at the cables outside and they booth look a bit cut up in one particular area. Cable 2 is worse with some of the silver outer wire showing. So initially I was going to by some connectors and a female and cut out the damaged part and fix it (because there's a lot of extra cable). Question 1 - would I be able to fix the damaged cable section in this way - I.E. is it possible to do what I am suggesting?
2nd Question - Did a bit more of an investigation and I took both the feeds out of the Sky box and put the working cable feed 1 into the 2nd slot on the sky box - but in signal settings its not getting a signal from the working cable. Now that the working cable is not working in the 2nd slot - could there be something wrong with the 2nd signal slot on the box? (Blown fuse or something). Tried cable 2 (non working cable) in 1st slot and that is not working either - therefore the cable is definitely damaged.
Any advice would be greatly appreciated
