sky by mobile
DustySox
I have set up my SE W800i, to record with my Sky+ box. Is it possible to set it up with the HD box as well, and if it is how would you be able determine which box you want to record.
atb
Darren
brendan_dj
darrenc said:
atb
Darren
Have you tried setting up two completely separate accounts?
Two different Sky viewing-card numbers, two different usernames and two different passwords?
Why not simply choose the same username and password as your Sky+ again, but with "HD" at the end of your username so that you can remember and distinguish them?
K
Kadders
OK - sounds like Sky by Mobile does work then! I downloaded it to my Nokia 6230i (supposedly supported), but when I run the app, it fails to connect.
Anyone got this working with a 6230i?
Shimmyhill
Does not connect on my Nokia 3230, will check the DS thread.
huntere
Yes
Followed instruction son DS thread. Oh I'm on O2 - servcie p[rovider does make a difference.
