Sky by mobile - remote record
MikeNolan
Has anyone used this new service offered by Sky allowing you to set up recordings via mobile handset. I am interested in the cost of using/downloading the menu system as opposed to sending a text message which costs 25p. Many thanks
Koptalk
Been trying to register for about 3 weeks now.
The lovely lady at sky told me to give it at least another 3,
due to problems!!.
:eek:
JayCee
Do a search of the "Sky" forum where you will find plenty of info/experiences on this.
cracker
it works well on my N80
generally to find the program i want to watch in the sky planner and set it record only takes about 16kb of data (it has a built-in counter)
mikeywinn
Works fine with me also. Much better having the planner than be charged for the texts as it comes out of my inclusive browsing allowance ! :D
Pug72
I have it working on my N80 but can't get my Sky+ box to register.
Keeps saying to check my phone line. Unplugged everything bar the Sky box and still get the same message.
Is it possible to reg the box over the phone?
MikeNolan
Glad to see that most people are having no problems, but can anyone else confirm the size of the downloaded data info and the prices they have been charged on their phone network. Thanks
phatspider
where do you get the n80 download - when i try it on my e61, n93 or n73 it says not supported device. is n80 now supported??
Similar threads
