Sky + but with standard Sky Subscription ?
Discussion in 'Sky Digital TV Forum' started by samotlofty, Mar 31, 2005.
  1. samotlofty
    samotlofty
    I may be asking the impossible, but does anyone know if it is possibble to use a Sky + box with a standard Sky card ? The reason I ask is that I don't have any premium channels, I'm not interested in recording/watching more than one channel at the same time and don't need the second LNB or cable. All I want to do is record one sky channel to the hard disk while I am out and want to set the recording using the Sky menu.
    Currently I think my only option is to buy a seperate hard disk recorder to connect to my standard Sky box and manually set the record times on the recorder.
    Any ideas ?
  2. johndon
    johndon
    Feb 3, 2002
    1,930
    48
    +89
    For the recording facilities to work, you need a Sky+ subscription.
    John
  3. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    For the full recording facilities to work, you need two LNB's. Someone else recently thought they could get away with one, and ran into all sorts of problems.
  4. RostokMcSpoons
    RostokMcSpoons
    Mar 1, 2005
    261
    Milton Keynes
    +7
    I can confirm that the Sky+ box will NOT record until you've phoned up Sky for them to enable it... and it's got to be connected to the phone line.
    You'd have to pay the £10 per month if you don't have 2 premium channels.
  5. samotlofty
    samotlofty
    Thanks for the replies. Looks like I may have to get the full Sky + package.
    thanks.
  6. tangers
    tangers
    Feb 21, 2005
    41
    +9
    At the moment you can get the Family pack, Movies 1 and Sports 1 for £28 for the first 3 months.
  7. shaithis
    shaithis
    Feb 25, 2005
    1,643
    The Last Aerie
    +31
    It doesn't need to be connected to the phone line if you've bought your own Sky+ box or you've had your Sky sub 12 months.
    I recently purchased a Sky+ box and rang them to get the card married to the new box and to get them to activate the Sky+ options......guy asked me to connect the phone line as it wasn't updating......I mentioned that card changes should come via the satelite signal and that I wasn't prepared, nor under contract to connect the phone line and he agreed.....2 mins later and my card had been updated.
  8. Dan L
    Dan L
    Feb 7, 2005
    2,201
    Wotton-under-Edge
    +110
    "I don't have any premium channels, I'm not interested in recording/watching more than one channel at the same time and don't need the second LNB or cable"
    You need a HTPC :)
  9. samotlofty
    samotlofty
    Forgive my ignorance but does HTPC mean Home Theatre PC ? and if I'm right would you recommend building one from a PC or buying a dedicated system off the shelf ? or can you point me to any good webs sites ?
  10. Dan L
    Dan L
    Feb 7, 2005
    2,201
    Wotton-under-Edge
    +110
    Yes you are correct.
    I'd personally recommend buying components to the spec you want, and making your own PC from it. Off-the-shelf ones are fine but may not meet all your requirements - and will probably cost a little more too. I wanted mine for occasional games-playing as well as HTPC use. I use Windows XP Media Center Edition on the software front.
    If you seriously want to consider going down this route, let me know and I will send you a few URLs for site which can supply HTPC cases and quiet components which you will need.
  11. samotlofty
    samotlofty
    Can you give me a few URLs so that I can get an idea of the specs and prices ?
  12. KITT
    KITT
    I too would be interested in any Media Center PC tips/info you might have. I'm planning on building one once I've moved into my new flat mainly to use for recording TV/Sky and playing mp3s.
    cheers :)
  13. lynx
    lynx
    Jan 20, 2002
    4,633
    It always rains.
    +301
  14. Cyril
    Cyril
    Jul 20, 2005
    1,113
    48
    +39
    Get a TiVo instead of sky plus and increase the picture quality with mode 0 and/or the SDI modification.
  15. stanleyntl
    stanleyntl
    Dec 6, 2003
    806
    28
    Worthing, Sussex
    +44
    Is it at all possible to record if you only have one LNB connected? Are the LNBs set so that input 1=watch input 2=record to HD, so you can't watch/record using 1 LNB? :(
    I was interested in the svideo out for my svhs vcr (given that a new Pace + box can be had for not much more than a new std receiver on ebay) : a SKY+ box can be used as a standard receiver okay? :confused:
