Sky Broadband
Discussion in 'Sky Broadband' started by sonyadudley, Mar 11, 2006.
  1. sonyadudley
    sonyadudley
    I've just downloaded the all new Sky by Broadband software but I can't run it. I downloaded the software first, successfully installed it and then updating the Windows Licenses about 6 times... but now finally tells me that I appear to be outside the UK!
    I think this is because I am with AOL and often their "ip address" is located in New York. the support team at www.sky-broadband.com have told me to contact aol for a different ip address. Does anyone else have the same problem or is just with aol?
  2. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    I use virgin and mine went straight in work first time flawlessly, i am quite impressed by this service and the picture is as good as sky direct and i download overnight when i am sleeping so no bandwidth worries.
    As far as Aol goes i am so glad to be rid of them, this is just typical of the hassles i used to have many moons ago when i didnt know better.
    AOL only likes aol compatable stuff, which is limited to aol. if you follow.
