Sky box wire question
Discussion in 'General Chat' started by p1tse, Aug 24, 2013.
  1. p1tse
    p1tse
    Jul 24, 2008
    2,974
    68
    +83
    I currently have a white sky box ie no HD
    The wire is a little too short, that's the two white cable joined together with a thin wire at the end which is screwed into to sky box.
    1. Can I extend this with some sort of DIY kit?
    I'm due a replacement new black box. Not signing up to Sky HD but the person said there are several free/ standard channels with HD.
    2. Would this require new cabling to what I currently have, so when I get this installed I can get the length to be extended at the sametime?
  2. the_watcher87
    the_watcher87
    Jan 3, 2008
    903
    46
    +102
    If it's a sky installer they should have no problem extending the cable but hit your DIY shop and buy 2 connectors, a male to male adaptor and a short length of coax if you want to DIY it. Shouldn't cost more than £1 or so and dead simple to do.
  3. RBZ5416
    RBZ5416
    Nov 4, 2002
    19,051
    +7,221
    You can buy extension cables like this. But you'll need another run for the second tuner anyway (unless what you're describing is shotgun cable) so may as well just get the installer to sort it.
  4. p1tse
    p1tse
    Jul 24, 2008
    2,974
    68
    +83
    Good to know there are extension types
    Got the new box coming in a couple of weeks so will ask if they can extend if using existing wire
  5. DrWise
    DrWise
    May 11, 2006
    10,641
    +1,057
    yeah the will extend the wire, when connecting the new box :)
    and they will leave some spare but bundled up
  6. p1tse
    p1tse
    Jul 24, 2008
    2,974
    68
    +83
    It's probably 50-100 cm short depending how I feed cable to tidy, but at the moment it's maxed out on reach to think about tidying wires
