Sky Box says: No signal....what to do?
Discussion in 'Sky Digital TV Forum' started by swbook, Jun 16, 2005.
  1. swbook
    swbook
    Hi all.
    I'm very new at this, and just got my Grundig 310/2 skybox today. I have
    a Triax dish with a standard LNB. I got both from a friend, since they were
    on his house when he moved in, and he doesn't care about such things.
    First my dish was set up on my 'elevated garden'(don't know the word), since
    it should be pointing pretty much south, and I would be able to turn the dish
    to face straight east if I wanted. I moved the dish very, very slowly, while
    looking at the screen menu with the lock-on etc, but nothing happened.
    Nothing at all! So, I checked the cable and F-connectors, cut them off, re-
    mounted them, and started over. No results. By the way, when I touch the
    F-connector that sits on the LNB, I get zapped...even when the MAINS have
    been disconnected from the skybox!? Is this normal? I had to unplug the F-
    con from the box, to be able to touch the other end at the LNB.
    Then I moved EVERYTHING to my first floor, to the outside garden there, on
    the other side of the house, and started again. No luck here either!! Like
    before, I don't get anything at all, from any sat.
    So, my question is, what is the commen fault in these cases? What are the
    odds that the LNB is toast? I didn't expect to home in on Sky right away,
    but I thought I would get something, just a short peak in signal strength
    or the like!
    Advice??
    THANKS for your time...AGAIN :clap:
    Nicholas
  2. swbook
    swbook
    Well, all of a sudden it found hotbird, out of the thin air:)
    Signal strength almost at max, quality at 50%.
    It says it's searching for channel listings, how long is this supposed to take?
    well over 15minutes now...
    Thanks!
    Nicholas
  3. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Sounds like you're on the wrong satellite ! You want 28.2 degrees east of true south. You may have found the 19.2 degree E satellite.
