Sky box says no phone connection, but there is?
ScouserAndy
My new HD box is saying it is not connected to the telephone line when it is. I've tried a phone in the socket the box plugs into and the phone works. Even changed the lead from the sky box to the phone socket.
Shall i do "new installation" again?
I dont want sky trying to charge me because they think i dont have the box pluged into the phone line!
Any ideas?
gjp
If you have BB you may need a microfilter connected into the telephone socket for your HD, I had the same problem and this resolved the problem.
ScouserAndy
I have a filter on it. Next test is to buy another extension i suppose and try that. I got the box from midsat. Is it there resposibility if the modem doesnt work?
Smurkenstein
Try the forced dial home in the installer setup - from memory, go services > system setup > 0, 1, select > option 3 > dialling type tone, set the dialling prefix to 1470 > save new settings > see if you get an error message...it might help
Smurkenstein
The other possibility is that you micofilter is fawlty...some of them are pretty poor quality...to check, try a normal phone through the phone side of the filter...
tig
I had this problem last year and tried the steps mentioned above to no avail.Eventually a sky engineer came round and discovered that the modem had failed and gave me a new box there and then.He said that every time he was sent round to have a look at a box with this problem he was told by sky to bring a spare.So looks like a known problem.
D
Darren73
Do you have BT 1571 on your line ? My Sky box often believes it's not connected if I have a message waiting as the dial tone is different.
Screwed up an old fax machine and laptop I had as well.
Johndm
Any ideas?
Double check you've not put phone plug into the ethernet socket......
I did......:oops:
mad_angler1
I did......:oops:
as has been said, check your in the phone connection and not the network one,
ScouserAndy
sorry havent replied, internet has been down. Problem was a faulty extension. Sky box works now. My only worry is, that when i installed the box and done the ring back when you do a new install, it wouldnt of phoned back. so do i need to do a new install again now the phone line works?
