Sky Box RGB to S-Video..best solution?
Discussion in 'Cables & Switches' started by saint_ade, May 2, 2005.
  1. saint_ade
    saint_ade
    May 2, 2005
    25
    3
    I have an Epson projector and am using the component input for DVD with progressive scan giving a fantastic picture. However, I'm not satisfied with my Sky digital box, which is connected from Scart to composite and gives a 'woolly' picture. I have a spare S-Video socket on the projector and was wondering what I need to connect the Scart out of the Sky box to the S-Video in on the projector. I'm assuming I need an RGB to S-Video converter, and then set the Sky box to RGB out. Is this right?
    Also, the converter boxes I've seen advertised seem to have a Scart out as well. Do you just then use a cable with Scart at one end and S-Video at the other? Can someone please reassure me or tell me the best solution before I buy?
    Thanks!
  2. Wannabe-THX
    Wannabe-THX
    Apr 7, 2004
    233
    Why not just go S-Video to S-Video? The V2 Sky boxes have one on the back.
    Fish
  3. Flimber
    Flimber
    Sep 22, 2002
    13,364
    Yorkshire
    +4,477
    Yes ! Sky+ Boxes and certain SkyNormal Grundig boxes have 's' out too.
    Mike.
    P.S. Welcome to the forums :)
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    you can also get RGB> YUV (component) converters if you have another component input or have componet swicthing on AV amp see JS Technology
  5. 28marcus
    28marcus
    Sep 21, 2004
    11
    3
    Hornydragon, your advices please,
    I have a similar problem;-
    1) NTL (Pace about to change to the new Samsung STB)
    2) SR8500 (Marantz) receiver.
    I note that I will need to convert RGB to use the AV switching facility on my AV unit.
    The JS Technology Component convertion solution is twice the price of the RGB to S-Video solution.
    I guess I'm asking, is the RGB component solution worth the price for a cable STB or should I go for the RGB to S-Video converter?
    Also the JS Tech solutions are both twice the price of similar solutions sold by Maplin, again is the outlay worthwhile?
    Thanks :rolleyes:
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    what display? 22" LCD not a problem, 50" PDP or PJ then the JS are well worth the extra........the SR8500 is a bit of a beast. give me some more info and I'll see what i can do (but if saving money is game use composite)
  7. 28marcus
    28marcus
    Sep 21, 2004
    11
    3
    Hornydragon
    Phew, thanks for the fast response :smashin:
    My display is the Panny PW6.
    DVD player is the Marantz DV9500 (all champagne :cool: )
    DV9500 to SR8500 IXOS Component,
    SR8500 to PW6 IXOS Component,
    Not making use of the DV9500 HDMi to SR8500 DVI-D due to the problems with DVI-D on the PW6, unless you can advise better.
    Ultimately the Plasma will go on the wall hence I wanted to make use of the AV switching so as to cut down on cables. I was going to wire up Component cables and a HDMI for future use.
    I purchased a Scart to S-Video for the NTL box and obviosly only got a black and white picture when I plugged it in. Fortunately for me searching this forum told me what was the problem, ie RGB output,
    All I need to do is put in the best solution. Cost is not really an option, but no one likes spending money unnecessarily.
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    marcus, THE JS RGB>YUV is the best option (apart from adding a scaler) i would wire at least one HDMI>HDMI Or DVi-D as that matches amp out put, cable into the wall and run 5 core analogue coax using 3 for componet and 2 spare (get you out of trouble cables)......ntl PQ is never going to set the world on fire but a JS RGB>YUV is the preffered option and compare to what you have already spent not a major cost..........(you could spend a grand on havin a scaler and goign all digital.......) also have you had or consdiered ISF calibration? see www.hoemcinemaengineering.com for more info
  9. 28marcus
    28marcus
    Sep 21, 2004
    11
    3
    Hornydragon,
    Thanks for that, Order processed for a JS Tech with you as a referal (hope you are on commission ;) )
    Must admit I have thought about ISF calibration and will probably go down that route. I'm having a problem with the MRAC stating an ambi noise error.
    Other posts suggest that fridges could be a problem! I've manually calibrated but can never get the subwoofer levels correct. Might get a sound calibration done too.
    Thanks again
    Marcus
