SKY+ Box RGB SYNC
Discussion in 'Sky Digital TV Forum' started by gwc, Oct 9, 2004.
  1. gwc
    gwc
    Oct 21, 2003
    499
    Wokingham, Berkshire
    +7
    Can anyone tell me what the SKY+ Box the format of the RGB signal. Is the sync on green or is there a separate sync signal.
    gwc
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    it should be RGBS sync is picked up from composite video signal
  3. Family Guy
    Family Guy
    That's correct yes...connected a few of these now to a Iscan HD and it works very well this way...
  4. sparkz
    sparkz
    Nov 21, 2002
    219
    19
    Southampton
    I'm trying to do this. What cable did you use? Does it have to have sync?
    Mark
