Sky Box Rgb Output
Discussion in 'Sky Digital TV Forum' started by Cowden_harley, Jun 9, 2005.
  1. Cowden_harley
    Cowden_harley
    Jun 6, 2005
    4,711
    FIFE, SCOTLAND
    +216
    i have a thomson sky digibox and it outputs at rgb. i have a lcd which inputs at rgb however when i connect the two up it gives m sound only no picture.
    any help?
    the inputs/outputs are scart
  2. uk_jih
    uk_jih
    Mar 17, 2003
    175
    +6
    Is your scart lead fully connected, some are not and the RGB does not work.
  3. Neville Street
    Neville Street
    Jul 11, 2004
    290
    +4
    Also check you have not pressed TV on the Sky remote. If you press TV it switches the signal from RGB to composite. I had the same problem as you previously, and it was pressign TV that did it. If you have sound and no picture and just press the Sky button the picture will switch back to RGB and will appear.
  4. Cowden_harley
    Cowden_harley
    Jun 6, 2005
    4,711
    FIFE, SCOTLAND
    +216
    thanks ill try them all.
  5. Cowden_harley
    Cowden_harley
    Jun 6, 2005
    4,711
    FIFE, SCOTLAND
    +216
    tried both no luck. do all scart leads support rgb?
  6. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    might sound silly but have you switched RGB on in the menu's?
  7. Cowden_harley
    Cowden_harley
    Jun 6, 2005
    4,711
    FIFE, SCOTLAND
    +216
    yep ched done that
  8. Bluevanman
    Bluevanman
    First, make sure that the scart is pushed fully home on both the box and the TV. If you still get no picture, try using a different scart lead,and can you try the box on a different TV?
  9. Cowden_harley
    Cowden_harley
    Jun 6, 2005
    4,711
    FIFE, SCOTLAND
    +216
    not really but ill try the scart lead again.
  10. Cowden_harley
    Cowden_harley
    Jun 6, 2005
    4,711
    FIFE, SCOTLAND
    +216
    thanks all got it to work just changed to a different scart cable thanks again.
  11. BigT
    BigT
    Jun 8, 2005
    70
    11
    Fareham, Hampshire
    might sound daft, but your not pluged in to vcr output of the sky box.
    pritty sure the vcr socket does not support RGB
  12. Cowden_harley
    Cowden_harley
    Jun 6, 2005
    4,711
    FIFE, SCOTLAND
    +216
    lol champ fan that was also part of the problem :rolleyes:
    i felt quite stupid.
