Sky box, RF Loop through or modulators
Discussion in 'Sky Digital TV Forum' started by Nil, Dec 7, 2004.
  1. Nil
    Nil
    I am going to get sky+ and mutiroom installed tomorrow, and I want to send the pictures to some other TVs in my house. But I want to be able to send analogue transmission as well as the sky transmission through some co-axial cables.
    So does the sky+ and sky box have only loop through RF or modulators, and how many. I hope it has 2 RF modulator outputs.
    Any answers much appreciated.
    Nil.
  2. Andrew K
    Andrew K
    Oct 14, 2004
    3,380
    +605
    I have mine set-up with the aerial input into the sky + box followed by one RF output going to the main display (as well as a scart connection) and the second RF output going to a distribution amplifier to feed the rest of the rooms. You have to remember in the set-up to turn the second output on as it defaults to off.
  3. Nil
    Nil
    Thanks katorik ,
    I guess that means you can mix an analogue signal into your co-axe cable. I'm planning to send the second RF from my sky+ to my standard sky box upstairs and then onto a distribution amp so the other tvs can tune in either box. I guess I have to change the RF frequency on one of the sky boxs first though.
    Thanks once again.
    Nil
