Sky+ Box Position
Discussion in 'Sky Digital TV Forum' started by Minty, Jun 24, 2015.
  1. Minty
    Minty
    Dec 2, 2000
    819
    96
    Co Sligo, Rep of Ireland
    +643
    Hi there
    Does the Sky + box need to sit horizontally on a shelf or can it be stood vertically.
    Not sure if the hard drive inside needs to be horizontal or not.
    Thanks in advance
    M
  2. kevkbuk
    kevkbuk
    Jan 27, 2011
    5,991
    +1,176
    The drive will be fine, you need to worry about stability and ventilation.
  3. enterthematrix
    enterthematrix
    Jan 14, 2012
    2,256
    Lisburn, NI (UK)
    +130
    I have mine sat vertically as there is no space left on my TV unit. I put 2 rubber feet under it to raise it up to help with ventilation.
    Haven't noticed any issues so far with heat etc.
  4. Minty
    Minty
    Dec 2, 2000
    819
    96
    +643
    Many thanks for replies. I am going to put it behind the tv which will be mounted on the wall. Due to the way the tv is
    made there will be plenty of room behind.
    M
  5. HDCriticalFan
    HDCriticalFan
    Feb 12, 2008
    1,364
    63
    +127
    Actually I think that the biggest ventilation issue arises from not enough air being able to be sucked in through the bottom of the unit. Putting it on its side would actually help here.
    Feet certainly help aid circulation too. I've cut two old squash balls in half to create four feet which raise my unit about 2cm. It makes the box appear to float and looks quite good !
  6. Member 719122
    Member 719122
    Jun 1, 2015
    91
    London
    +11
    Horizontal is the preferred position as long as the ventilation holes on the sides of the 360 console are not blocked. You could place for example some DVD cases underneath the console to elevate it a little for ventilation. You have probably done this but if not, keep your 360 in an open area and not in a cabinet where the air cannot circulate. Hope you get it sorted.
  7. John
    John
    Dec 13, 2002
    11,683
    +3,350
    That is all well and good, but how does that help with standing the SkySTB on its edge ;)
  8. V F
    V F
    Dec 16, 2010
    421
    28
    +65
    What about the remote sensor?
  9. Minty
    Minty
    Dec 2, 2000
    819
    96
    +643
    @V F There is a toaster with shiny sides and the signal rebounds of this an works the Sky box.
    Seems to work well.
    The toaster is far enough away not to cause any heat issue.
    M
