sky box on its side okay
RobTi
Looking to put my sky hd box in a cupboard and was wondering is there any problem positioning it on its side?
Robert
Rockinraver
Ive had my Sky HD box on its side since early February and the only problems i have encoutered are those which seem to afflict the masses from software updates etc.
I posted a similar thread at the time and one chap had been through several boxes which the engineer suggested was caused by the boxes position but he was either very unlucky or I am very fortunate.
Mine is mounted on its right hand side. I believe the fans are on the left.
skyguy69uk
Robert
hi robert.i've been installing sky since 1989 and it should be ok to put your hd box on its side aslong as it's properly upright and not at an angle. also be aware that if the box is installed in a closed cupborad,some ventillaton will be necessary.cheers,paul,carlisle
