I've seen the auctions on eBay. Requires special remote code apparently. Not sure if it works or not but I'm very dubious. Even if it does, surely Sky would catch you after a few uses anyway, wouldn't they??? Surely they'd have a record of who's accessing what and whether it matches their subscriptions on paper??? *shrug*
And let's not forget, it's illegal and therefore is not condoned on the forum
The "code" that you would pay for would simply change the telephone number the box dials when buying ppv... when the STB reaches it £50 limit it wont work and it needs to phone the correct number to clear the limit and therefore you will get charged.
The same con involves using a 9v battery and a box that looks like a telephone point... all these cons work until your stb reaches the £50 limit and after that you can't order any more PPV until sky clears it.
And before you ask, there is no other way to reset the credit limit.
