Sky box model number
sideshow bill
Hi, simple question and I'm a tad peeved I cant find it myself but I'm programming my Harmony one for all and I need to input the model....
Scotty Pro
If its a SKY HD + 500gig box then it should be on the bottom of the box, at least mine was, or try the model number listed in my sig below.
sideshow bill
It is a 500 gb box, I'll have a look tonight. I thought I'd be able to find it via the service menu but the model number on there was the same as the software verion number
logiciel
This should be in the Remotes forum, where, coincidentally, it's just been answered.
They all use the same commands so model numbers don't come into it and you simply select the default entry at: Add Device> Video Recorder> PVR> Sky which is actually the same as Scotty Pro's.
