Sky Box Locking Up Help Required
Discussion in 'Sky Digital TV Forum' started by Vicksburg, Aug 10, 2005.
  1. Vicksburg
    Vicksburg
    Can anyone help? My Sky Box (Pace approx. 4 yrs old) is locking up, in that all the remote and Box controls cease to function The only remedy is to unplug the box from the mains for about a minute. This is happening 2 or 3 times a night. Any suggestions or is the box US. Any help would be appreciated.
  2. Laskina
    Laskina
    Had a simliar problem - got worse when I moved it into an enclosed space when I changed my set up and noticed it was getting hotter than before (it also had another piece of av equipment under it).
    I put a spacer inbetween and the units which seems to have made it be cooler. Not had the problem since.
    So could be overheating ...
    Nick
    PS For the spacer I took the aluminum cases you get with those small candles. Removed the wax and turn upside down - it gives you about a 3cm gap between the units and doesnt look too bad :)
  3. Vicksburg
    Vicksburg
    Thanks, but I don't think it's an overheating problem, on the bottom shelf of AV
    stand, plenty of ventilation, but thanks anyway.
  4. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Next time it happens, don't switch the box off, but try disconnecting both LNB cables for about a minute. You could have a faulty LNB.
  5. Vicksburg
    Vicksburg
    Thanks Nick, will try that today.
  6. riffmeister
    riffmeister
    Jul 26, 2005
    I had a similar problem with my 6 month old Sky+ box. I didn't think it could be a cooling problem as it was on a shelf on its own on my Optimum stand.
    However, the problem has gone away since I rearranged the equipment and moved the box from the second bottom shelf to the second from the top. Originally it was at a height of about 10" from the ground as is now at about 24" from floor level.
    I have absolutely no idea why this has made such a difference as the ambient temperature around the stand is pretty much the same as room temperature. Maybe I just knocked something back into place when I moved the box?
    If all else fails it's got to be worth a go!
    Good luck.
