Sky Box Into A Hitachi Tx100 How ????
Discussion in 'Sky Digital TV Forum' started by bluesteel, Sep 19, 2004.
  1. bluesteel
    bluesteel
    Sep 19, 2004
    652
    +20
    Hi I am trying to view sky using my projector
    I have tried to output sky via an RGB scart into a trilogy one box and ought of that into my projector using a scart to composite lead
    however my projector reports no signal found on composite
    is there a setting im not aware of im at my wits end!!!!!
    It works fine using my dvd player and the above method
    PLEASE HELP ME!!!!!!!!!!!!!!!
  2. bluesteel
    bluesteel
    Sep 19, 2004
    652
    +20
    no one knows?
  3. seasider
    seasider
    Jul 8, 2004
    41
    Blackpool
    I had the same problem connecting via a Lektropacks RGB-to-component conversion box to a Sanyo projector. Despite trying every Scart cable I could from the Sky box (and copiously swearing) I couldn't get anything other than a snowy picture. In the end I bought a Scart to 15-pin D-plug from Keene Electronics (product code SBB92) on the recommendation of another forum member and that works really well. What I can't tell you is how it matches up to component - but it's one hell of a lot better than a black screen of frustration. Now all I've got to do is get rid of that red dot...
