I got a free sky + box through that recommend a friend deal. I have a plain box already upstairs just for freesat so the installer just used the same dish.
The sky + box downstairs is very slow compared to my one upstairs like for example when going through the channels it doesnt go immediatly it takes a few seconds then goes which is very very annoying. Sometimes the picture is a bit sticky and sometimes channels go off saying no signal. The box even sometimes freezes!
I have phoned up sky and they are sending an engineer down. Has anyone else had similar problems?
I was thinking of buying a sky HD box off ebay and using that instead as I have just purchased a kdl-40v3000. I have read that the standard channels will look alot better through the hd box, is that right? Is installing the hd box as simple as just plugging it in and phoning sky to link the box to my card? Also do I have to subscribe to HD channels having the HD box because I just want it to view my normal channels off.
Thank You
Thank You
