Sky box Grundig - Keeps switching off.
nunew33
I have a four year old grundig (will update with model number later).
It keeps switching off (ie green to red light), then powering off (ie lights go out) then after a couple of seconds powering on (to red) and after a few more seconds it allows me to switch.
Doing this on a daily basis?
Any ideas? Something I can fix or terminal?
nunew33
Great site. PSU repair kit and cpu cooler now winging its way to me!
jimcarney
Nunew33, Did you find an answer to your original post , because mine mirror box has been doing the same thing . Thanks in advance . Jim
nunew33
Jim. From sat cure im guessing its the psu on its way out and an overheating cpu.
Cutting out and then restarting later sounds like a heat related problem, so getting a fan in sounds like a good idea. And with satcure saying a psu >12 months on a grundig Im guessing it would be better to get uprated capacitors.
Will let you know if its successful by weeekend!
Podcast: REL T9/X Subwoofer + Bowers & Wilkins PI7 Reviews, AV Shows in a Pandemic and more
