SKY+ Box Fan Noise
Discussion in 'Sky Digital TV Forum' started by viewer, Oct 21, 2004.
  1. viewer
    viewer
    Sep 26, 2004
    91
    Had SKY + installed. 2 days later a clear whining noise was comming from the Box (armstrad). Engineer came and replaced the box with a Pace box - said it was better than Armstrad. There was no fan noise heard from the Armstrad box but from the Pace box you can clearly hear the fan when it comes on - it is not constant but annoying - same as computer fans.
    Is it me or do others also have the same problem. Can you hear the fan running in your Pace box.
  2. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    The fan in my v2 Pace box is on all the time even though it's in a well ventilated cabinet - I think it's something to do with the last software update.
    It's only audible is everything else is switched off and there is no other source of noise in the room.
    John
  3. screemer
    screemer
    Jul 7, 2004
    1,458
    48
    Southport
    +50
    Yeah i had my Amstrad swapped to a Pace last night cos of dreadful picture quality. The Amstrad had a high pitched whirring sound which the pace doesn't but the Pace fan is slighly louder. I can cope wit ha fan noise compared to a high pitched noise though.
