Sky+ box content after multiroom room.....
Discussion in 'Sky Digital TV Forum' started by waveydavey13, Feb 10, 2009.
  1. waveydavey13
    waveydavey13
    Jul 12, 2008
    930
    2
    +67
    Hi all,
    We're having Sky HD fitted next week and having our existing Sky+ box moved to the bedroom as a multiroom install.
    Sky said that our existing viewing card would go in the new HD box and the Sky+ box would have a new viewing card upstairs. I never thought at the time to ask but will we still be able to access all the programs we have on our sky+ box after it's been moved or do we need to get everything on the box watched before it's moved upstairs??
    Dave.
  2. stevelup
    stevelup
    Aug 13, 2002
    6,795
    Swindon
    +1,300
    It would be much better if the new card went in the new box otherwise you will indeed not be able to watch the content on your old box.
    Can't see why they can't do it that way round though?
  3. stevelup
    stevelup
    Aug 13, 2002
    6,795
    Swindon
    +1,300
    Actually, I might be talking nonsense. In fact, I almost certainly am...
    Best wait for someone who knows what they are talking about to answer!
    Thinking about it some more, you should be fine either way round.
    Steve
  4. fernandez
    fernandez
    Jun 5, 2005
    6,039
    +995
    Doesn't really matter which way it's done.
    If Sky issue a new card for the old Sky+ box now to be used as Multiroom, then the new card will be activated against the receiver details (paired/'married') and all features and recordings made on that box will still be available
  5. Broadz
    Broadz
    Oct 4, 2006
    8,697
    +1,423
    ....except for recordings of premium channels (Sky Sports and Sky Movies). These require the card that was present when the recording was made (so the card which is now housed in the Sky HD box) and also requires that card to be paired with that box (which it won't be; it'll now be paired with the HD box).
  6. stevelup
    stevelup
    Aug 13, 2002
    6,795
    Swindon
    +1,300
    Right - that's what I thought at first...
    So why don't they just put the new card in the new box?
  7. fernandez
    fernandez
    Jun 5, 2005
    6,039
    +995
    Yes, you're right as this bears out
    Will I lose my recordings? - Sky+ - Digital Spy Forums
    So, as suggested in above thread
    The best options are:
    1. Make sure cards stay with original boxes - call Sky to repair (this can be hassle as they often claim it is "impossible" - it isn't)
    2. Copy contents of original box to new one with Copy+
    3. Swap card when you wish to view - but this is a pain as discussed
    At least nothing has been done yet so now's the time to sort it.
    Good luck
  8. waveydavey13
    waveydavey13
    Jul 12, 2008
    930
    2
    +67
    Thanks for the replies guys.....
    I take it then that any recordings from premium channels wouldn't be viewable if the original card wasn't moved with the sky+ box but any from BBC, ITV etc would be???
    If that's the case that's not too bad....... I've also had contradicting info from Sky themselves!!!! One person i asked said all recordings would be viewable and the other said none would be!!!!! :rolleyes:
    Dave.
  9. pcbbc
    pcbbc
    Jul 23, 2003
    397
    28
    London UK
    +84
    The way Sky will want to do things:
    Current card in new HD box, new card issued for existing Sky+ box
    Result:
    All old recordings EXCEPT ones from FTA channels (BBC, ITV etc) will be totally unwatchable
    Workaround:
    Return original card to old box temporarily to allow viewing. However premium content (movies and sports) will never be viewable without repairing.
    What you can do (as already suggested):
    a) Call Sky and repair the cards round the right way. Often a pain as they either claim it is impossible, or if they do do it they don't do it right leaving you without the ability to do anything on either box. In this case everything remains viewable (once Sky do their job right).
    b) Copy your recordings from old box to new HD box. A bit of hassle I agree, but the advantage is the recordings stay in the main room - which is presumably where you'd wish to view them!?
    c) Swap cards back when you want to view. Okay for one offs, but not so great in the long run because you can not record anything while you do this and also doesn't work for premium content (movies sport).
  10. waveydavey13
    waveydavey13
    Jul 12, 2008
    930
    2
    +67
    Sorry but i'm a little confused....... If i was to temp put the existing card from the new HD box into the old plus box would i or would i not be able to view all recordings.
    Sorry to be a pain..... It's been a long day. :confused:
    Dave.
  11. davemurgatroyd2
    davemurgatroyd2
    Dec 26, 2004
    8,600
    Oxford
    +1,335
    You will be able to watch all recordings from non Premium channels - i.e. everything except Sky Movies and Sky Sports which require the original card to be paired to the box.
  12. waveydavey13
    waveydavey13
    Jul 12, 2008
    930
    2
    +67
    That's great..... At least we only have to watch the premium stuff then watch all the rest at our leasure.
    Thanks for the help guys.
    Dave.
