Sky Box connections
Discussion in 'Sky Digital TV Forum' started by areuwithmee, Sep 2, 2005.
  1. areuwithmee
    areuwithmee
    Hi all
    Could someone please tell me what some of the connections on a standard sky + box are for?
    Such as rf 1 and rf 2 output? Also where are outputs if I want sky in other rooms?
    Many Thanks
  2. areuwithmee
    areuwithmee
    Also people say who should connect an rf output from your vcr to your rf input of sky. WHY?
  3. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    The RF outputs are there so you can run sound and vision to another room - they also allow the use of a magic eye to change channels on the box from another room.
    To view Sky in another room, you could also use the s-video and audio phono outs - this would give better picture quality than the RF.
    There is need to connect the RF of a video and Sky box together as the connection can be made via scart. The only reason I can see for doing this is if you also want to receive and record terrestrial analogue signals and even then it's vital that you daisy chain via the sky box.
    HTH
    John
  4. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    RF1 and RF2 are the coaxial outputs (standard RF cable).
    Both of these carry a RF modulated signal (with mono audio) on a user set frequency. RF1 is a standard connection(no different to one on a VCR) while RF2 can carry a small voltage which allows the TVlink system (remote access from another location) to work.
    For basic operation there is no need for a RF link between the digibox and VCR, scart is so much better. However some people have a need to distribute not only the SKY signal but the VCR output and Terrestrial together so passing the RF feed from the aerial through the digibox then through the VCR and into a distribution amp has it's uses.
  5. areuwithmee
    areuwithmee
    Thanks chaps.
    If I connect rf 1 or 2 output directly into the tv, would I recieve terrestial channels as well as sky also?
  6. JayCee
    JayCee
    Jan 20, 2004
    22,327
    Lanarkshire
    +2,327
    Only if you have a terrestrial aerial connected to the RF in socket.
  7. areuwithmee
    areuwithmee
    Thanks 4 reply guys.
    If I didn't connect my terrestial aerial to the input on the skybox and just ran the outputs (rf1 or rf2) will I still pick up sky channels on say channel 6 but no terrestial channels right?
  8. JayCee
    JayCee
    Jan 20, 2004
    22,327
    Lanarkshire
    +2,327
    I presume you mean you have prog 6 on your TV tuned to the Sky digibox in which case.......yes.
