sky box but no viewing card
Discussion in 'Sky Digital TV Forum' started by sloth, Sep 24, 2005.
  1. sloth
    sloth
    Sep 4, 2005
    1,043
    48
    +61
    hi,
    possibly a silly question. i have just had sky+ installed and have a third cable from the dish which i am going to connect the old box to in the bedroom. i know you can buy a ftv/fta card from sky to get the freesat service, but having looked at the website at the list of available channels i am wondering if it is worth it. my question is, if i just connect the old box to the dish but with no card in will i receive anything at all on it?
    thanks
  2. JayCee
    JayCee
    Jan 20, 2004
    22,311
    Lanarkshire
    +2,324
    Yes, BBC1, BBC2 and some (mainly) home-shopping channels.
    You will not get ITV, CH4 or CH5 without a card.
  3. sloth
    sloth
    Sep 4, 2005
    1,043
    48
    +61
    thanks for your help
  4. sloth
    sloth
    Sep 4, 2005
    1,043
    48
    +61
    hi,
    another question if you don't mind. i have just connected up the box in the bedroom and all seems to be working fine, although as you say a very limited amnt of channels. i have noticed though that i can receive pretty much all of the radio stations on the box. As this appears to be the case is anything stopping me using the digibox as a dab radio receiver with my hi-fi seperates?
    i should be able to type in the channel number from memory as obviously there won't be an on screen display but that is not really a problem. i assume i can connect it to the amp using normal hi-fi leads (red/white ones) what connection on the amp should i plug it in to as i have an analogue tuner at the moment plugged into the tuner connections which i want to leave as it is.
    thanks for any help
  5. Crocodile
    Crocodile
    Nov 4, 2002
    18,332
    +6,859
    You can use any spare input on the amp with the exception of Phono.
  6. JayCee
    JayCee
    Jan 20, 2004
    22,311
    Lanarkshire
    +2,324
    Ideally any input marked "AUX"
  7. SamRadford
    SamRadford
    Jul 12, 2005
    3,965
    103
    N. Yorkshire
    +308
    See http://sam-radford.me.uk/ftv.htm
