SKY Box and Plasma Probs
Discussion in 'Plasma TVs Forum' started by pablow, Oct 24, 2005.
  1. pablow
    pablow
    Oct 21, 2005
    10
    I was told that it was best to connect my sky box via Scart-Componant. I purchased the required cable and plugged it in to be met with a pink picture which was moving constantly. i have changed my settings to use RGB in the sky box but the same happens. Tried in my DVD player same problem, although when i change it to NTSC it stays pink but the picture doesn't move!
    running everything through S-Vid at the moment. taken cable back to shops and changed for another one same results.
    Am i missing somehting?
    thanks
  2. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
  3. ukdan
    ukdan
    Feb 16, 2005
    1,136
    swindon
    +85
    What cable is it?
    If your trying to connect scart to component then you will need a converter like the js tec rgb to component converter which imo is the best out there.
  4. pablow
    pablow
    Oct 21, 2005
    10
    Plasma is LG MZ-42PZ17 using the tech+Link cables not the most expensive i know but i would off hoped for something.
  5. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    but you're taking an rgb feed and pluuging it into a component input so you wont get anything however good the cables are, without a converter.
  6. pablow
    pablow
    Oct 21, 2005
    10
    the cable i have is a Scart to componant!
  7. pablow
    pablow
    Oct 21, 2005
    10
    ok, guess i will give up on that then! back to S-Video!
  8. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    it will only carry an RGsB signal (from sky and your dvd's scart) whereas your input board on the plasma is looking for component
  9. pablow
    pablow
    Oct 21, 2005
    10
    ok, so it is iseither get a decent DVD player that supports Componant, or get a convertor for both. thanks for your help
  10. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    you could use a scart extender (one that you plug two scarts into) and just the one converter
  11. sekrof
    sekrof
    Dec 14, 2004
    9
    Not sure if this helps atall, but I had a similar issue when connecting my Sky+ box to an HD+ (video scaler) via Component. I eventually found the cable I needed: See the this thread for more details ...
  12. kingsize
    kingsize
    Jul 16, 2004
    1,038
    +49
    I am running my set up as follows:
    Sky+ to Sony HX510 recorder via Thor Scart; HX510 (set to progressive)to Plasma (Hitachi 7200) via compnent.
    When I select component on the Plasma and run Sky+ throught the DVD to the Plasma - getting a far better picture.
    Is it component? Don't know but it is noticeably better.....
  13. pablow
    pablow
    Oct 21, 2005
    10
    will look into it!
    does anyone use the rs232 output on the skybox?? any good?
    thanks
  14. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    some dvd recorders convert an RGB feed to component
  15. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    i think the rs232 is just for engineer purposes and is not an output
  16. pablow
    pablow
    Oct 21, 2005
    10
    ahh ok, that makes sense!
