Sky Being installed tomorrow, what cables?
Discussion in 'Sky Digital TV Forum' started by Lego, Jun 15, 2005.
  1. Lego
    Lego
    Down to you lot, i decided to get + downstairs then have multiroom in my room.
    I just bought a 26"LG LCD for my bedroom, and am wondering which cables would be best to output the sky. I'm also using Logitech z5500's which i'm hoping i can attach too, but i'm not to worried about those.
    I've been reading that i need a Scart-RGB cable? is that just a normal scart or something different.
    Sorry if this is a stupid question, i just dont want to get it wrong.
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    A standard scart cable should be fine, set the digibox for RGB and make sure you connect the cable to a RGB scart on the LCD. You may later on decide to invest in a more expensive scart cable which may or then again may not help sustain the quality of the signal between the two units.
