Sky+ basic info needed
Discussion in 'Sky Digital TV Forum' started by malcom, Mar 18, 2002.
  1. malcom
    malcom
    Aug 25, 2001
    526
    +4
    When copying sky+ recorded material to a VHS or DVD recorder can you fast forward or reverse to locate the part of a program that is required for copying! Or does the "copy" function just copy the entire program without allowing to select specific parts.
    For example if I recorded the Stars in their eyes show but only wanted to copy one or two of the performances. Is the Sky+ recorder suitable for this purpose. regards. malcom
  2. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,906
    71
    50 Rue St Georges, Paris.
    +32
    malcom, the Skyplus+ will feed recorded programmes through to your vcr, even when not using the copy function. I often edit adverts out of episodes when copying onto vhs. It's just like copying from another vcr, but with much higher quality, of course.
