Sky + Back question
Discussion in 'Sky Digital TV Forum' started by ABBITEA, Sep 12, 2003.
  1. ABBITEA
    ABBITEA
    Dear All,
    Just changed from NTL cable to Sky +. The cable remote had a back button i.e. if you pressed it, it would take you back to the previous channel shown. This allows for great flicking.
    I can't seem to find this function with Sky +. Does it exist.
  2. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    Nope ;)
  3. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    One of the more obvious and useful commands/functions which was present on SKY analogue yet vanished when SKY switched to digital.
    On the bright side you will find that more of your viewing will be recorded/time shifted and you'll soon learn channel numbers even if you choose not to use the favorites option.
