Sky+ & Autoview
Discussion in 'Sky Digital TV Forum' started by Black20VT, Jun 8, 2005.
  1. Black20VT
    Black20VT
    May 4, 2005
    369
    +13
    We previously had regular Sky, but now have Sky+, but I can't see 'autoview' anymore? :eek:
    Is autoview no longer available on Sky+? Is it just a Sky thing?
    Please help, as I miss it.
    :lease:
  2. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,858
    2
    In a secret location with Jennifer Lawrence
    +9,715
    Haven't had Sky for a while, just on Sky+, was autoview the thing were you marked a programme and when it was about to start the channel would automatically change?
    if so, Sky+ does not have this feature. I think the only way it will automatically switch to a channel is if you have two programmes set to record at the same time and you are currently watching a third channel. Not sure which of the two it switches two, but it does switch to one of them.
    Greg
  3. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    SKY+ has never had that feature, there may have been a need for it when it could only record a single channel at any time allowing the second tuner to be used to feed an external recorder but these days with dual recording it would serve very little purpose.
  4. Member 55145
    Member 55145
    Jan 18, 2005
    12,079
    +3,480
    actually im ****** off it doesnt have it, is there any other way of setting up a reminder so you dont miss the start of your program? yea yea i know it will record it but that means you have to set it to record, and then when you remember its on its half way thru it so you have to
    a) watch it till the end then rewind and watch the begining
    b) rewind as soon as you remember its on then watch it 10-15 mins out of sync which means time important programs like call in programs or QVC *EURG* would be messed up(Very annoying, if thats even possible?)
  5. Greg Hook
    Greg Hook
    Nov 25, 2001
    22,858
    2
    +9,715
    Not sure exactly what you are getting at here.
    The beauty of Sky+ is that you can set things to record and watch them back at your leisure. There is no rewinding of any kind with Sky plus. You can start watching a programme back at any time, from any point in the programme. Plus I usually try and watch stuff 15 mins out anyway as it means over an hours programme you can skip all the adverts.
    Apologies if I have missed your point.
    Greg
  6. RichA
    RichA
    Apr 28, 2005
    49
    11
    Putney
    You can set reminders with sky+.
    From memory...just use the select button instead of the record button.
    A screen memo will pop up reminding you to change channel to... It won't however change channel for you (which is probably best)
    Rich
  7. Member 55145
    Member 55145
    Jan 18, 2005
    12,079
    +3,480
    Cheers RichA
    GH you can only go back to the begining of a program that you had set to record tho right?
    My problem would be I wouldnt want to record everything, but more importantly id want a reminder to pop up to tell me something has started so i can watch it live. No point in turning over to big brother(Spit) if the votes have already been in, no amount of rewinding will let you vote
  8. RichA
    RichA
    Apr 28, 2005
    49
    11
    Putney
    J-P
    Correct can only start from the beginning if has been set to record. But this CAN be done at any time. i.e. set BB (!) to record. 20 mins later go find it in the sky+ section and hit play - no rewinding req'd.
    Also, you were criticising - just turn over and rewinding - can't be done anyway. As the tuner has not been on this channel it would not be able to rewind.
  9. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    I think the reminder auto-channel change function was disabled in Sky+ to avoid recording conflicts.
