SKy+ Audio Connection
Discussion in 'Sky Digital TV Forum' started by themmings, Feb 6, 2003.
  1. themmings
    themmings
    Nov 21, 2002
    380
    Northampton
    +4
    What audio options (i.e. Sky+ to AV Amp) are available?
    Is it just phono 2 phono?
    Tim:)
  2. AOD
    AOD
    Feb 7, 2001
    714
    London
    +5
    The Sky+ box also has a digital audio output connection (don't know what type, Toslink (optical) or SPDIF (electrical).
    Certain Sky Film channels broadcast in DD 5.1 and this is the only box that can output that.
  3. DaveP
    DaveP
    It's Optical
    DaveP
  4. boltoa
    boltoa
    Oct 10, 2002
    917
    2
    46
    Nottingham
    +103
    There is a standard Sky box by Sony that also has an optical out and decodes the 5.1DD, apparently.
    Andrew
  5. Davo
    Davo
    Mar 20, 2002
    12
    the Sony does have an optical out, but sadly doesn't decode the 5.1...
  6. AOD
    AOD
    Feb 7, 2001
    714
    London
    +5
    I can vouch for the Sony Sky box with the optical out.
    It sends out Stereo PCM @ 48Khz which sounds a lot better through my Tag AV32R than using the DACS in the Digibox (shudder!)
  7. themmings
    themmings
    Nov 21, 2002
    380
    Northampton
    +4
    Thanks folks for your comments.
    That's another optical cable I can add to the shopping list then:rotfl:
    Tim
