Sky at 50" / spending £5K
Discussion in 'Plasma TVs Forum' started by sleepa, Jun 19, 2004.
  1. sleepa
    sleepa
    Jan 20, 2004
    27
    Maidenhead
    Hi Gurus...
    Is it in any way realistic to run a (probably panny) 50" somehow without using a processor? Or an HD 42" for that matter?
    I assume DVD would be fine as is, using something like den 2900 prog into component. Sky and/or TiVo (60%) is the concern...
    Ideally I would like to grab a price sweetspot SD and ringfence the £2-3K saving for an upgrade in a couple of years.
    It's the flicker and the lower greyscale/banding that's stopping me; Can these 2 'features' be tempered by processing at all?
    If so might that be a decent compromise (with the processor carrying over through the upgrade) or is there another pitfall with this idea?
    Also (while I have you here :smoke: ), is one processor is better suited to the Panasonics than another?
    Grateful for any input.
