sky around house in quality video
Discussion in 'Sky Digital TV Forum' started by pacemaker, May 28, 2005.
  1. pacemaker
    pacemaker
    Aug 31, 2003
    546
    +17
    is there a way of piping sky around house in rgb or svideo?
    new build so no worries on cabling
    seen cat5 system but still converts composite only
    looking for something that will concvert svid/rgb to another format and back again in rooms
    cheers
    ps if only you could get a sky pci card for pc
  2. caersiddi
    caersiddi
    Apr 28, 2003
    13
    Wales
  3. hao
    hao
    I have sky on six TV sets around the house using normal aerial coax. Cable from additional TV output on back of Sky box to an aerial distributon box, then to each TV set.
  4. pacemaker
    pacemaker
    Aug 31, 2003
    546
    +17
    thanks but was hoping to get better quality ie rgb so can connect a plasma and projector at same time with sky box in remote area
  5. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Everything is possible - at a price. If you use high quality cables and distribution amps, you can do this, but it won't be cheap.
