J
jon_burrows
How long does it take for Anytime to fill up? I had HD installed on Saturday morning and I thought it would've (at least partially) filled up by now.
I don't think you do need to leave the box in standby for Anytime to fill up. Back when I had my TiVo, my digibox was on 24/7, I never put it into standby and always got Anytime stuff.
You DID enable Anytime in the settings, did you not? If so then the above timetable is pretty normal.
Do you need to have your HD box connected to your phone line for Anytime to work?
Nope. Mine hasn't been connected for nearly two years. Is your Anytime STILL not working???![]()
Nope it's still not working. Phoned up sky tech dept. Everything seems ok with the settings and equipment. Then they said I need to have the box connected to the phone line. I didn't think that was correct. So I'm still stuck without Anytime.
OK. Let's try this;
Go into Settings again. If Anytime is switched ON, then switch it OFF, Save Settings on the green button.
Exit the menu completely.
Then go back into Settings and re-enable Anytime, again make sure you save settings.
Can't think of anything else to get it up and running.
