Sky+ anyone noticed?
Discussion in 'Sky Digital TV Forum' started by SteveRSF, Sep 19, 2004.
  1. SteveRSF
    SteveRSF
    Nov 10, 2003
    270
    mine is taking a while to change channels and it says (must wait for recording to finish)or something ..........."Im not recording anything" .......you damn machine!
    er soz for the rant..the other thing is the progs i have recorded some of em have gone even the ones that were recorded a few days ago that i aint watched yet!
    any ideas what i can do guys?.............. :confused:
  2. Family Guy
    Family Guy
    Have you tried a system reset?
  3. SteveRSF
    SteveRSF
    Nov 10, 2003
    270
    Pulled the plug out for two mins and pluged it back in if thats what ya mean? :eek:
  4. Family Guy
    Family Guy
    Yes that's it. But to reset it properly you need to do it in this order:
    Remove the viewing card.
    Remove the plug from the wall or from the back of the machine.
    Wait 2 minutes.
    Plug machine back in.
    Turn it on and insert viewing card when prompted...try that. If that dosen't work, you may have to do a planner rebuild or a a complete housekeep. We'll go through if you need to do it (unless you know how to do it already of course... :) )
  5. SteveRSF
    SteveRSF
    Nov 10, 2003
    270
    no, thats great army bloke cheers will try that! :)
  6. NC11
    NC11
    Sep 19, 2004
    459
    London
    +7
    I've got the same "slow response" problem on my week old box. It's the Amstrad 180 which is suppose to be newer than the Pace V2 but it takes ages to flick between the channels. Also when I use the remote I sometimes have to press twice or tree times before I get a response. My daugther also complains about the same issue when playing some games on the Disney channels.
    Is that common or do I need to replace the box. I think it has the latest Sw on it.
    Cheers.
  7. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +975
    Turn the Instant Rewind off, see if that makes a difference.
