Sky + and Yamaha rxv630rds
Discussion in 'AV Receivers & Amplifiers' started by zippo4, Sep 24, 2004.
Tags:
  1. zippo4
    zippo4
    Oct 28, 2001
    Kent
    I've just connected my Sky+ box to my Yamaha rxv630rds via an optical cable. It all sounds fine to my uneducated ears but I was wondering if the amp is picking up the signal correctly? Shouldn't the amp change it's surround mode automatically when it 'hears' the Sky audio in Dolby? Much like when I put on a DVD the amp flips to 'Enhanced' mode? Or am I confusing Dolby with Surround sound?
    Any help/advice appreciated
  2. John
    John
    Dec 13, 2002
    11,284
    +2,894
    If your amp display is the same as mine it would display the following
    L R in the bottom right hand corner
    prologic II in the top left
    PCM just underneath
    When I switch to Movies 1 2 or 3 , when a DD movie is on .Amp autoswitches over
    Think you may well be confusing DD and DPL
    atb
    john :thumbsup:
  3. zippo4
    zippo4
    Oct 28, 2001
    Kent
    Ah, I see. So if I was watching a DD film on Sky Movies then the display should change to show the number of speakers 'working' once the signal has been processed by the amp?
    Is that correct?
  4. John
    John
    Dec 13, 2002
    11,284
    +2,894
    yep , thats right :smashin:
