SKY and using both SCART sockets
Discussion in 'Sky Digital TV Forum' started by Swiss-Steve, Nov 2, 2005.
  1. Swiss-Steve
    Swiss-Steve
    Jun 9, 2004
    127
    +11
    Hi Everyone,
    I am trying to connect my SKY sat box, and use both SCART sockets,
    But No Go,
    as soon as I connect the second SCART (TV), I get no picture on the VCR SCART socket.
    I am using a VCR SCART cable to my DVD-R Hard Drive recorder,
    The second TV SCART with a SCART to Component convert for my Projector.
    I have swaped both SCART plugs, but it didn't fix the problem.
    Has anyone experienced this before?
    Or have an idea on how I can get both SCART's working?
    I appreciate any Help
    Steve
  2. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    are you using a converter or just a scart to component cable?...if the latter your pj has to accept an RGsB input on component
  3. Swiss-Steve
    Swiss-Steve
    Jun 9, 2004
    127
    +11
    No, It is a converter,
    The QED unit.
    The Projector is a Marquee 9500LC, and does not have a RGBs input,
    only RGBVH.
    I am using a HD Lezza as the scaler from the SKY/SCART/Component to CRT
    Steve
  4. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    So you get a picture to the DVDR when it is the only one connected?
  5. Swiss-Steve
    Swiss-Steve
    Jun 9, 2004
    127
    +11
    Yeah,
    As soon as I plug the other SCART in, out goes the picture
    Weird
    I may just have to get a SCART switch, then switch the output to the display I am watching, or the DVDR
    Steve
  6. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    why dont you go: sky tv scart to dvdr, dvdr to Projector (via converter)?
