Sky+ and tv link
Discussion in 'Sky Digital TV Forum' started by maximus desimus, Dec 27, 2002.
  1. maximus desimus
    maximus desimus
    Hi all
    happy new year 2 all
    i have just got a tv magic eye set it up no probs
    heres the question
    do i need to get another sky+ remote to turn it over from the bedroom or is there a way to use the sky remote that came with it
    i think its for a normal digi box not a sky + one
    thanks for any help
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    There are slight variations between the remotes used to control a standard digibox but you should be able to alter the codes to give you minimal control of SKY+ (None of the recording features though).
    To reprogram the sky remote to control the sky+ box.
    The sequence is:
    TV
    Blue+select led flash twice
    2
    Select
    Sky
    (From satcure)
    I just bought a second SKY+ remote, little point not having full control of the SKY+ from another room.
  3. TimF
    TimF
    From where did you buy a second sky + remote and how much.
  4. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    I bought mine last year from Satcure for around £25 I think and SKY sell them of course.
  5. thfccambs
    thfccambs
    Jul 17, 2002
    23,952
    White Hart Lane
    +6,898
    Got my extra sky+ remote from sky for £20 all in.there's some on ebay at the moment as well.
  6. maximus desimus
    maximus desimus
    thanks for the help done as you said but only got the remote to change channels up/down cant put any numbers in ,ie, 501 sky news have to just go up and down
    any ideas
    thanks
  7. thfccambs
    thfccambs
    Jul 17, 2002
    23,952
    White Hart Lane
    +6,898
  8. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    I think there have been at least three designs of the standard SKY remote so maybe that sequence only works with one of them:(
