Old remote to change channel on a sky plus box This depend on which Sky remote you have there have been at least three versions
The sequence is:
TV
Blue+select led flash twice
2
Select
Sky
Now the sky remote up and down channel buttons change the channels on a sky+ box.
To revert back, enter this sequence again but press the zero button instead of "2".
if that doesnt work try this
1.Press T.V. button on your original remote
2.press yellow and select together until the led on the remote flashes twice.
3.press "1"
4. press select the led flashes twice
5.press the blue button
There you have it your remote should change your channels from the T.V.link point. if it doesnt you will have to buy a new remote
Good luck
