Sky+ and Sky???
Discussion in 'Sky Digital TV Forum' started by chez, Jan 5, 2004.
  1. chez
    chez
    Feb 25, 2003
    1,549
    41
    Dallas, TX
    +19
    Does Sky+ use the same IR codes as Sky?
    Reason I ask is that I'm considering getting Sky+ in my lounge but keeping the existing Sky box as well, so I could have PIP with 2 sky channels.
    Only problem would be remote controlling them individually if they use the same codes??
    Can anyone tell me if they use the same codes? If so, is there any way around this?
    Chez
  2. STOWITBELOW
    STOWITBELOW
    Nov 17, 2002
    1,578
    48
    Lancashire
    +49
    Sky remote doesn't readily operate + (Even with tweeking it ony does an odd + function), so they are not the same.
  3. chez
    chez
    Feb 25, 2003
    1,549
    41
    Dallas, TX
    +19
    Are they different enough to allow them to be used simultaneously in the same room?
  4. Dave777
    Dave777
    Oct 25, 2002
    479
    Gatwick
    +8
    Yes, you can use both in the same room. Don't fiddle with either controller and they won't interfere with each other. I'm doing that myself and it is fine.
    Dave
  5. chez
    chez
    Feb 25, 2003
    1,549
    41
    Dallas, TX
    +19
    I would be using my Pronto to control them, so as long as I program it correctly, this should be OK?
    Chez
  6. MarkR
    MarkR
    May 3, 2003
    1,845
    Somewhere in Kent
    +296
    I have Sky+ and a normal sky digi box in the same room. I have configured my Pronto to work for Sky+ and it doesn't interfere with the other one.
  7. chez
    chez
    Feb 25, 2003
    1,549
    41
    Dallas, TX
    +19
    Great, thanks guys :)
  8. ANDY DUTTON
    ANDY DUTTON
    hi im andy just noticed that you have a multi remote i have the mosiac 1 4 all i think the codes are the same have you got the code for a sky + remote
    your help is appreciated
    cheers andy
